Nyakundi
Common Problems Toyota Voxy Owners May Face & How to Solve
If you own a Toyota Voxy, you may encounter the following issues.
1. Electronic Key or Ignition Problems
Click this link to download the Toyota Voxy Owner’s Manuals, depending on the year of manufacture.
- If the digital key malfunctions or is lost, the engine may not start properly.
- In such cases, manual override using the mechanical key is necessary.
- A dead battery can result in the engine not starting or the electronics malfunctioning.
- Warning systems and accessories may be affected if electrical components or accessories are improperly installed.
- The Voxy includes tire repair kits or emergency tires, depending on the model.
- Low air pressure or incorrect tire type (e.g., winter tires, chains) can lead to driving hazards.
- Problems with radar, cameras, or sensors used by:
- SRS airbags may not deploy correctly if the seats are damaged or modified incorrectly, or if passengers sit too close together or in the wrong position.
- Post-collision checks are crucial, even if the airbags do not deploy.
- CO poisoning risk if the car is idling in closed spaces or with snow-blocked exhausts.
- Owners are warned against leaving the vehicle running in garages or snowbanks.
- Incorrect use or installation of child seats (especially on the front seat) may lead to fatal injuries in airbag deployment situations.
- The manual includes detailed instructions on ISOFIX and seat belt-based installations.
