Daihatsu Hijet In Kenya: Expert Review, Price & Trusted Sellers
Daihatsu Hijet
The Daihatsu Hijet is a light freight vehicle that has been in production since 1960. The name “Hijet” was created to imply that the vehicle offers higher performance than the Midget.
The first-generation Daihatsu Hijet had bonnet-type light vans and light trucks, but the second-generation models were changed to cab-over vans and trucks. However, the ninth-generation model changed from a van to a cargo type to a semi-cab type, which is still the case today.
The Daihatsu Hijet is valued by owners as a “working partner” in a wide range of industries, from agriculture to delivery and online taxi.
In Kenya, the Hijet competes with the Honda Acty, Mitsubishi Minicab, Nissan Clipper, Subaru Sambar, and Suzuki Carry.
Daihatsu Hijet Interior, Exterior and Engine Options​
The Hijet has a spacious interior that comfortably seats four people. The truck version seats only two. The cabin has been modified over the years and is now in its eleventh generation, modern and equipped with a number of convenient and comfortable features. These include a push start button, a pop-up rear window, an intelligent interior mirror, air conditioning, and a small infotainment screen.
The exterior design is bold and reassuring with attention to detail. The Hijet’s boxy shape is achieved by extending the top of the rear and reworking the angle of the front pillars to maximize load capacity and create a spacious cabin. The Hijet is fitted with highly visible LED tail and stop lights and the rear door has a wide and flat surface, making it easy to add the Hijet name.
The Daihatsu Hijet is powered by either a 658cc DOHC DVVT or a KF-VET type 658cc straight 3 DOHC DVVT turbocharged engine. The two engines are mated to either a 5-speed manual transmission or a CVT.
Difference Between Hijet Caddy, Hiject Cargo, Hiject Truck​
The Hijet Caddy is designed for light business use and usually seats 2-4 passengers. It has a microvan shape. The Hijet Cargo is built with maximum cargo capacity in mind. It also seats 2-4 passengers but with a large space for cargo. The Hijet Truck is primarily designed for open cargo transport. It has a mini-truck exterior and a cargo bed added to it. The Hijet Truck can only carry 2 people.
Where to Buy the Daihatsu Hijet in Kenya​
If you are looking to buy the Daihatsu Hijet in Kenya, importing is the best option due to the following reasons:
Quality – You get to choose the best quality car. You are not at the mercy of the local dealers. Cars sold locally are usually of the lowest quality and often of high mileage.
Choice – With import, you get to dictate the choice of features that you want. You can define your preferences in greater detail such as color, upholstery, sunroof, alloy rims, etc.
Affordability – Import is much more affordable since you eliminate middlemen and brokers that exaggerate the cost of locally sold cars.
If you are considering importing the Daihatsu Hijet, please get in touch with us through our contacts: [email protected], call 0722469360, or chat with us directly on WhatsApp below and we will guide you through the process.
For a wider selection of Daihatsu Hijet models with various colors, mileages, and specifications, visit DEALER.CO.KE
