Howo 6x4 Tipper | Topcar Kenya
The Howo Tipper 6x4 is a heavy-duty dump truck positioned slightly below the Howo-TX 8x4 Tipper. Its presence on Kenyan roads has multiplied significantly owing to its affordable acquisition cost, high-load capacity, versatility, and low operational costs. The spare parts and service parts are...
The Howo Tipper 6x4 is a heavy-duty dump truck positioned slightly below the Howo-TX 8x4 Tipper. Its presence on Kenyan roads has multiplied significantly owing to its affordable acquisition cost, high-load capacity, versatility, and low operational costs. The spare parts and service parts are readily available, hence their warm reception in the country. It sits in the same category as the FAW J6P, Isuzu Giga series, MAN TGS, Mercedes-Benz Actros, and Volvo FMX.
Howo 6×4 Tipper
Before you read, we would like to let you know that we sale the Howo 6×4 Tipper in Kenya. If you are considering to import the Howo-TX 8X4 Tipper, click here to fill out our contact form https://topcar.co.ke/import-your-car/ and we will get back to you immediately or email us directly via [email protected]
The Howo 6×4 Tipper is a suitable choice for the following functions;
- Transportation of bulk materials (sand, gravel), demolition debris, waste materials, farm products, and heavy bulk cargo.
Howo 6×4 Tipper
INTERIOR & EXTERIOR
The Howo 6×4 Tipper has a functional and practical cabin. Modern features like power windows, automatic climate control, air suspension seats, and a centralized door lock enhance convenience.READ ALSO: BRABUS XL 800 CABRIO
The sleeper berth is standard and provides a comfortable resting place. Multiple storage compartments are present, as well as an AM/FM Radio and a USB connectivity that caters to the entertainment needs of the occupants.
Howo 6×4 Tipper
The Howo 6×4 Tipper is smaller in size compared to the bigger Howo-TX 8×4 Tipper. Similar to other Howo trucks, LED headlights and daytime running lights are present. The boxy bed can haul tons of freight thanks to the heavy-duty suspension system.
Howo 6×4 Tipper
ENGINE & PERFORMANCE
The Howo 6×4 Tipper features a single engine option. A ZZ3257V3647B1R 11.596 L WEICHAI POWER 6-cylinder in-line with 4 valves, water-cooling, turbocharging & intercooling.READ ALSO: Toyota Coaster Review
Howo 6×4 Tipper
This engine produces 400 horsepower at 1900 RPM and 1800 NM of torque at 1000-1400 RPM.
The powertrain is linked to a manual gearbox, 10 forward and 2 reverse, with PTO (Power-take Off).
SPECIFICATIONS
Permissible Loading Capacity on Chassis: 11,500 kgCurb Weight: 14,500 kg
Gross Vehicle Weight (with trailer): 26,000 kg
Front Axle Loading Capacity: 9,500 kg
Rear Axle Loading Capacity: 16,000 x 2 kg
Howo 6×4 Tipper
Chassis Length: Frame (double layer with section of 300x80x8 mm)
Front suspension (10 semi-elliptic leaf springs)
Rear suspension (12 semi-elliptic leaf springs)
Fuel Tank Capacity (300 liters) with a locking fuel cap
READ ALSO: Howo-TX 8×4 Tipper
Howo 6×4 Tipper
Clutch: single plate dry diaphragm spring clutch, diameter 430mm, hydraulically operating with air assistance.
Propeller Shaft: double universal joint propeller shaft with gear-shaped coupling flange
Howo 6×4 Tipper
Parking Brake: Spring energy, compressed air operating on rear wheels
Auxiliary Brake: Engine exhaust brake
Fuel Tank Capacity: 300 liters
READ ALSO: 2025 Bentley Flying Spur
Howo 6×4 Tipper
Voltage: 24 Volts
Batteries: 2×12 Volts, 180 Ah
Alternator: 3-phase, 28V, 1540W
Starter: 24V
Howo 6×4 Tipper
For a wider selection of Howo 6×4 Tipper models with various colors, mileages, and specifications, visit DEALER.CO.KE
Howo 6×4 Tipper
VIDEO REVIEW: 2025 Cherry Tiggo 8 Pro
If you are considering to import the Howo 6×4 Tipper, click here to fill out our contact form https://topcar.co.ke/import-your-car/ and we will get back to you immediately or email us directly via [email protected]
