Howo H3 Tipper 6×4 Load 16 Tonnes
The Howo H3 Tipper Load (16 tonne) is a robust 6x4 heavy-duty dump truck produced and marketed by Sinotruk. Its entry into the African market, or even the Kenyan market for that matter, is already giving the likes of FAW Jiefang, Isuzu F-Series, Tata Prima, Ashok Leyland Ecomet, and Mercedes-Benz Actros a run for their money. The H3 Tipper offers a striking balance between payload capacity and maneuverability compared to the heavy-duty tippers. It makes an excellent choice for individuals or businesses looking for a reliable, affordable, good engine torque, and a high payload capacity.
Howo H3 Tipper
Howo H3 Tipper
Before you read, we would like to let you know that we sale the Howo H3 Tipper in Kenya. If you are considering to import the Howo H3 Tipper, click here to fill out our contact form https://topcar.co.ke/import-your-car/ and we will get back to you immediately or email us directly via [email protected]
Howo H3 Tipper
Howo H3 Tipper
The Howo H3 Tipper is a suitable choice for the following functions;
  • Transporting bulk loose materials (sand, gravel, minerals, construction materials)
  • Servicing construction and infrastructure projects
  • Efficient unloading (The hydraulic system lifts the cargo box for a speedy delivery)
  • Construction sites
INTERIOR & EXTERIOR
The Sinotruck Howo H3 Tipper has a driver-centric cabin that is spacious, practical, and comfortable. The famous air suspension seat greatly reduces driver fatigue during long drives or even when navigating rough terrains.
READ ALSO: Toyota Fortuner Review
Howo H3 Tipper
Howo H3 Tipper
Electric windows & doors, central locking, remote key, and power windows enhance convenience. An AM/FM Radio and a 12-volt power outlet are also incorporated.
The Howo H3 Tipper has a modern front fascia that is characterized by LED headlights & daytime running lights, a chrome-accented Sinotruk emblem, and a robust bumper.
Howo H3 Tipper
Howo H3 Tipper
ENGINE & PERFORMANCE
The Sinotruck Howo H3 Tipper comes with a single engine option. A WP4.6NQ220A 4580cc inline-four Diesel churning out 220 horsepower at 2,300 RPM and 800 NM of torque at 1200-1800 RPM.
READ ALSO: Sinotruck Howo H3
Howo H3 Tipper
Howo H3 Tipper
This powertrain is connected to a 10-speed manual transmission with 2 reverse gears.
Maximum speed is 80km/h
SPECIFICATIONS
Cab Width: 2080mm
Wheelbase: 3100 + 3150mm
Chassis Length: 6580mm
Recommended Inside Box Size: 4500mm (length) 2200mm (width) 1400mm (height)
Ground Clearance: 277mm
Howo H3 Tipper
Howo H3 Tipper
Gross Vehicle Weight: 28,000kg
Chassis Kerb Weight: 9,395kg
Front Axle Loading Capacity: 5,000kg
Rear Axle Loading Capacity: 2×10,000kg
Howo H3 Tipper
Howo H3 Tipper
Clutch: 350 diaphragm spring clutch, single plate
Steering System Type: Hydraulic system
Front Axle: 153D (5T) forging i-beam, drum brake
Rear Axle: 153s (10T) central single reduction, drum brake i=6.83
Suspension: semi-elliptical leaf springs, shocks + stabilizer (FRONT)
spring suspension (REAR)
Parking Brake: Spring energy, compressed air operating on rear wheels
Auxiliary Brake: Exhaust valve braking (EVB)
Fuel Tank Capacity: 200 liters
Howo H3 Tipper
Howo H3 Tipper
Voltage: 24 Volts
Batteries: 2×12 Volts, 120 Ah
Alternator: 28V/ 80A
Starter: 4.5 kW
Howo H3 Tipper
Howo H3 Tipper
For a wider selection of Howo H3 Tipper models with various colors, mileages, and specifications, visit DEALER.CO.KE
READ ALSO: 2024 Mercedes-Benz E-Class
Howo H3 Tipper
Howo H3 Tipper
VIDEO REVIEW: 2025 Toyota Land Cruiser 300 GR
