Howo-TX 8x4 Tipper | Topcar Kenya
The Howo-TX 8X4 Tipper is a heavy-duty 12-wheel dump truck that is highly revered by folks and commercial companies in the mining industry, construction industry, or large-scale bulk material support. Its powerful engine, reinforced chassis, strong load-bearing capacity, and proven driveline...
The Howo-TX 8X4 Tipper is a heavy-duty 12-wheel dump truck that is highly revered by folks and commercial companies in the mining industry, construction industry, or large-scale bulk material support. Its powerful engine, reinforced chassis, strong load-bearing capacity, and proven driveline components make it a standout Tipper amongst the likes of the Shacman F3000, Scania XT 8X4 Tipper, Mercedes-Benz Arocs 8x4 Tipper, and Volvo FMX 8X4 Tipper.
Howo-TX 8×4 Tipper
Before you read, we would like to let you know that we sale the Howo-TX 8X4 Tipper in Kenya. If you are considering to import the Howo-TX 8X4 Tipper, click here to fill out our contact form https://topcar.co.ke/import-your-car/ and we will get back to you immediately or email us directly via [email protected]
The Howo-TX 8X4 Tipper is a suitable choice for the following functions;
- Transporting sand or gravel to and from construction sites
- Carrying extracted materials from quarries and mining sites
- Moving large quantities of materials for major projects
- Operation in complex terrains (off-road or muddy paths)
- Heavy load carrying
Howo-TX 8×4 Tipper
INTERIOR & EXTERIOR
The Howo-TX 8X4 Tipper cabin offers a blend of space, comfort, and functionality. The driver and co-driver seats are very supportive, thanks to the air suspension system that makes driving enjoyable and less fatiguing.
Howo-TX 8×4 Tipper
The sleeper berth is quite comfortable and provides a resting place after long hours of driving. The steering wheel is power-assisted, hence the tipper adapts effectively to road curvature. A heating and ventilation function is standard for enhanced comfort levels. Safety features incorporated in this car include a lane departure warning, forward collision warning, and safety belts.
READ ALSO: 2024 Mercedes-Benz E-Class
Howo-TX 8×4 Tipper
The Howo-TX 8×4 Tipper has a robust and modern appearance. Its utilitarian design makes it a perfect choice for heavy-duty activities. Massive tires, a U-shaped bucket cargo box, thick steel, a hydraulic system for unloading, and heavy-duty suspension systems define its commanding aura. It is available in a spectrum of colors.
ENGINE & PERFORMANCE
The Howo-TX 8X4 Tipper features a single engine option. A (WP12.400E201, Euro 2 emission) 11.596 L WEICHAI POWER inline-6 with 4 valves, water-cooling, turbo-charging, & intercooling.READ ALSO: Toyota Prado Review
Howo-TX 8×4 Tipper
This engine produces 400 horsepower at 1900 RPM and 1800 NM of torque at 1000-1400 RPM.
The powertrain is linked to a manual gearbox, 10 forward and 2 reverse, with PTO (Power-take Off).
SPECIFICATIONS
Permissible Loading Capacity on Chassis: 11,500 kgCurb Weight: 14,500 kg
Gross Vehicle Weight (with trailer): 26,000 kg
Front Axle Loading Capacity: 7,000 kg
Rear Axle Loading Capacity: 16,000 x 2 kg
Chassis Length: Frame (double layer with section of 300x80x8 mm)
Front suspension (10 semi-elliptic leaf springs)
Rear suspension (12 semi-elliptic leaf springs)
Fuel Tank Capacity (300 liters) with a locking fuel cap
READ ALSO: Howo Rigid Truck 6×4
Howo-TX 8×4 Tipper
Clutch: single plate dry diaphragm spring clutch, diameter 430mm, hydraulically operating with air assistance.
Propeller Shaft: double universal joint propeller shaft with gear-shaped coupling flange
Howo-TX 8×4 Tipper
Parking Brake: Spring energy, compressed air operating on rear wheels
Auxiliary Brake: Engine exhaust brake
Fuel Tank Capacity: 300 liters
Howo-TX 8×4 Tipper
Voltage: 24 Volts
Batteries: 2×12 Volts, 180 Ah
Alternator: 3-phase, 28V, 1540W
Starter: 24V
For a wider selection of Howo-TX 8X4 Tipper models with various colors, mileages, and specifications, visit DEALER.CO.KE
Howo-TX 8×4 Tipper
VIDEO REVIEW: 2025 BYD Dolphin Surf
