Sinotruck Howo H2 Rigid Load 5,7 & 10 Tonne
The Sinotruck Howo H2 Rigid load is a light & medium truck primarily designed for urban mobility and logistical support with a tonnage of 5,7 & 10, which is ideal for its purpose.
Sintotruck Howo H2
Sintotruck Howo H2
Sinotruck CNHDTC (China National Heavy Duty Truck Company) is a leading Chinese heavy-truck manufacturer that made its debut in 1950 and has since become a major player and global supplier of light, medium, and heavy trucks. The Howo series is its brand bearer, renowned for producing haulage tractors, concrete mixers, rigid trucks, tippers, and dumpers.
Sintotruck Howo H2
Sintotruck Howo H2
The Howo series is regarded as a successful entrant into the market, especially in Asia and Africa, where you can barely cover a kilometer without sporting one. Affordable acquisition cost, high build quality & engineering, reliability, durability, excellent fuel economy & operating cost, advanced safety features, and after-sales parts availability & dealer network are the hallmarks that have contributed to its success.
Sintotruck Howo H2
Sintotruck Howo H2
As we debut the review of light, medium, and heavy-duty trucks here at Topcar Kenya, the Sinotruck Howo H2 Rigid Load will start us off into the world of rugged capability and industrial power.
READ ALSO: 2025 Lexus GX 550
Sintotruck Howo H2
Sintotruck Howo H2
Before you read, we would like to let you know that we sale the Sinotruck Howo H2 Rigid Load in Kenya. If you are considering to import the Sinotruck Howo H2 Rigid Load, click here to fill out our contact form https://topcar.co.ke/import-your-car/ and we will get back to you immediately or email us directly via [email protected]
Sintotruck Howo H2
Sintotruck Howo H2
Sintotruck Howo H2
Sintotruck Howo H2
The Sinotruck Howo H2 Rigid load makes an ideal choice for commercial operators who are looking for a robust flatbed/cargo/box with a stellar fuel economy. The icing on the cake is its affordable acquisition cost. Its perfect blend of payload and maneuverability makes it applicable in the following sectors:
  • Light construction & utility support
  • Light industrial and commercial applications, e.g, moving freight from one warehouse to another.
  • Temperature-controlled transport, e.g, can be used as a refrigerator truck for transporting perishable goods like farm produce.
  • Regional/Urban logistics
Sintotruck Howo H2
Sintotruck Howo H2
GRADES
H2 34
H2 38
H2 45
INTERIOR
The Sinotruck Howo H2 has arguably the best-looking cabin in its class. Experienced drivers have been accustomed to utility and durability in a cabin, which is quite okay, but if you are driving for a long distance, you want to experience a comfortable drive.
Sintotruck Howo H2
Sintotruck Howo H2
This truck offers a seamless blend of practicality and comfort. The air suspension driver seat is quite supportive, and it absorbs road imperfections for a refined driving experience.
READ ALSO: Baw Warrior- The Untamed Truck & SUV
Sintotruck Howo H2
Sintotruck Howo H2
The driver has excellent visibility and command of the oncoming traffic. An AM/FM Radio caters to the entertainment needs of the occupants. Other features include power windows, remote key & central lock, electric doors, and multiple storage compartments.
Sintotruck Howo H2
Sintotruck Howo H2
ENGINE AND PERFORMANCE
The Sinotruck Howo H2 features a single engine option. A 2,970cc WPN3NQ160AO Euro 3 four-cylinder diesel engine that produces 160 horsepower at 3000 RPM and 480 NM of torque in the 1400-2300 RPM.
This powertrain is connected to a 6-speed manual transmission (gearbox model- WLY6G55) with the following gear ratios:
1-6.198
2-3.287
3.-2.025
4-1.371
5-1.000
6-0.780
It has a maximum speed of 110-120km/h.
READ ALSO: Hyundai Palisade
Sintotruck Howo H2
Sintotruck Howo H2
SPECIFICATIONS (H2 34, H2 38, H2 45)
Cab Width 1880mm (H2 34) 2080mm (H2 38) 2080mm (H2 45)
Wheelbase 3360mm (H2 34) 3800mm (H2 38) 4500mm (H2 45)
Chassis Length 6160mm (H2 34) 6970mm (H2 38) 7800mm (H2 45)
Chassis Width 2230mm (H2 34) 2360mm (H2 38) 2400mm (H2 45)
Ground Clearance 220mm (H2 34) 203mm (H2 38) 203mm (H2 45)
Sintotruck Howo H2
Sintotruck Howo H2
Gross Vehicle Weight 9,900kg (H2 34) 12,000kg (H2 38) 12,000kg (H2 45)
Chassis Kerb Weight 2,90kg (H2 34) 3,200kg (H2 38) 3,600kg (H2 45)
Front Axle Loading Capacity 3,200kg (H2 34) 4,000kg (H2 38) 4,000kg (H2 45)
Rear Axle Loading Capacity 6,700kg (H2 34) 8,000kg (H2 38) 8,000kg (H2 45)
Sintotruck Howo H2
Sintotruck Howo H2
Clutch: 350 diaphragm spring clutch, single plate
Steering System Type: Hydraulic system
Suspension: 11-semi-elliptical leaf springs, shocks + stabilizer (FRONT)
9 + 7 semi-elliptical leaf spring (REAR)
Service Brake: Dual-circuit airbrake
Parking Brake: Spring energy brake
Auxiliary Brake: Exhaust brake
Fuel Tank Capacity: 120 liters
Electrical System Type: SINOTRUCK CAN Bus System with VCO instrument
Voltage: 24 Volts
Batteries:
2 x12V, 120Ah (Ampere-hour)
Alternator: 20V/ 80A
Starter: 4.5 kW
VIDEO REVIEW: 2025 Range Rover Velar
Sintotruck Howo H2
Sintotruck Howo H2
For a wider selection of Sinotruck Howo H2 models with various colors, mileages, and specifications, visit DEALER.CO.KE
Sintotruck Howo H2
Sintotruck Howo H2
