This factory wiring diagram is critical for circuit tracing, power and ground verification and for pinpointing signal paths for the Air Fuel Ratio Sensor connector D35. It provides you with the precise connections needed to execute terminal-level voltage and resistance testing on the sensor's heater circuit and reference lines to the engine ECU. Any attempts to troubleshoot an air to fuel ratio circuit without the OEM schematics is extremely risky since any small mistep can destroy the ECM.
- What is the pinout chart for the Toyota Harrier ASU60/ASU65 air-fuel ratio sensor D35 connector?
- How do I check for proper voltage supply at the Toyota Harrier ASU60/ASU65 A/F sensor heater?
- What are the wire colours for the 8AR-FTS engine air-fuel ratio sensor on a Toyota Harrier?
- How do you diagnose a signal circuit fault at the D35 sensor plug without destroying the ECM?
Click on the link below to access the complete OEM Manual, within it you will find the Air Fuel Ratio Sensor Wiring Diagram. I have given the screenshot below to help you quickly navigate to the section where the diagram is located. Once you find it, you can then print or save it. Let me know if you face any challenges or have any questions and I will be happy to answer in the thread below. Please note that the year in the document is not the YOM but the document release date so it covers the entire model range. Also note the document applies to all countries where the model is sold Including Singapore, Australia, Malaysia, Kenya, UK, New Zealand, etc.- Access to the OEM Manual
