Toyota Harrier ASU60/ASU65 Throttle Body Wiring Diagram
This OEM diagram gives the complete circuit tracks, wire colour codes and connector pinouts for the D23 plug assembly. It enables you to precisely test sensor reference voltage supply drops, test actuator motor lines and isolate electrical line faults from actual mechanical plate restrictions. Without it, you risk making pinning mistakes on the sensitive D23 sensor loop which can damage data network lines and the ECM.
Common questions that this document answers​
  1. What is the pinout chart for the throttle body D23 connector on a Toyota Harrier ASU60/ASU65?
  2. How do I test the throttle actuator motor circuit on a Toyota Harrier ASU60/ASU65?
  3. What are the wire colours for the dual throttle position sensor harness on a Toyota Harrier 8AR-FTS engine?
Click on the link below to access the complete OEM Manual, within it you will find the Throttle Body Wiring Diagram. I have given the screenshot below to help you quickly navigate to the section where the diagram is located. Once you find it, you can then print or save it. Let me know if you face any challenges or have any questions and I will be happy to answer in the thread below. Please note that the year in the document is not the YOM but the document release date so it covers the entire model range. Also note the document applies to all countries where the model is sold Including Singapore, Australia, Malaysia, Kenya, UK, New Zealand, etc.
Toyota Harrier ASU60 ASU65 Throttle Body Wiring Diagram
