Symptoms
Gears slipping
Delay to engage gears, delay in upshift and delay in downshift
Knocking sound when shifting
Causes
Shift solenoid problems
Wrong ATF viscosity
Low ATF
Dirty ATF
Leaking ATF
Solution
Service gearbox
Replace faulty solenoids
Use correct viscosity ATF
Replace gearbox
To buy Mark X Gearbox in Kenya, Visit: https://yoka.co.ke/ad-category/spare-parts/toyota/toyota-mark-x/
Mitigation
Timely service and maintenance
Use correct ATF as per Owner’s manual
Gears slipping
Causes
Wrong ATF viscosity
Low ATF
Dirty ATF
Leaking ATF
Solution
Service gearbox
Replace gearbox
Mitigation
