Symptoms
Knock and jerking when shifting gears
Problem engaging gears
Gear shift problems – does not shift, delay in upshift, delay in downshift
Gears slipping
Loss of power
Causes
Low ATF
Dirty ATF
Leaking ATF
Delay in replacing ATF
Worn out CVT belt
Sensor problems
Solution
Service gearbox
Replace ATF
Replace CVT Belt
Replace sensors
Replace gearbox
To buy the gearbox visit: https://yoka.co.ke/ad-category/spare-parts/toyota/premio/
Mitigation
Timely service and maintenance
Use correct ATF as per Owner’s manual
Gears slipping
Loss of power
Causes
Low ATF
Dirty ATF
Leaking ATF
Worn out CVT belt
Sensor problems
Solution
Service gearbox
Replace ATF
Replace CVT Belt
Replace sensors
Replace gearbox
Mitigation
