Symptoms
Gear shift problems – No shift, delayed upshift, delayed downshift, shifts to wrong gear
Gears slipping
Poorly timed shift
Loss of power
Jerking and knocking sound when shifting
Causes
Faulty gearbox ECM(Electronic Control Module)
Low ATF
Dirty ATF
Leaking ATF
Delay in replacing ATF
Worn out CVT belt
Solution
Service gearbox
Replace ATF
Replace CVT Belt
Replace ECM
Replace gearbox
To buy the Toyota RAV4 gearbox visit: https://yoka.co.ke/ad-category/spare-parts/toyota/toyota-rav4/
Gears slipping
Poorly timed shift
Loss of power
Causes
Low ATF
Dirty ATF
Leaking ATF
Worn out CVT belt
Solution
Service gearbox
Replace ATF
Replace CVT Belt
Replace ECM
Replace gearbox
