Symptoms
Whining noise
Transmission slipping
Delay to engage gears, delay in upshift and delay in downshift
Jerky shifts
Causes
Shift solenoid problems
Wrong ATF viscosity
Low ATF
Dirty ATF
Leaking ATF
Solution
Service gearbox
Replace faulty solenoids
Use correct viscosity ATF
Replace gearbox
Mitigation
Timely service and maintenance
Use correct ATF as per Owner’s manual
Whining noise
Jerky shifts
Causes
Wrong ATF viscosity
Low ATF
Dirty ATF
Leaking ATF
Solution
Service gearbox
Replace gearbox
Mitigation
