This manufacturer guide shows you where every electronic part, actuator and module is located inside the cabin, engine bay and chassis. Having this structural map saves you time and prevents damage by aiding you go direct to the component you need to work on. Attempting to service hidden modules or sensors without this OEM map can be tedious, risky and time consuming.
Common questions that this guide answers
- Where is the adaptive cruise control module mounted on a 2013-2020 Toyota Harrier?
- How do I locate hidden interior sensors behind the dashboard on a third-generation Toyota Harrier?
- Where can I find the official factory structural position map for parts on a 2013-2020 Toyota Harrier?
How to access the guide
Click on the link below to access the complete OEM Manual, within it you will find the Component Location Guide. I have given the screenshot below to help you quickly navigate to the section where the guide is located. Once you find it, you can then print or save it. Let me know if you face any challenges or have any questions and I will be happy to answer in the thread below. Please note that the year in the document is not the YOM but the document release date so it covers the entire model range. Also note the document applies to all countries where the model is sold Including Singapore, Australia, Malaysia, Kenya, UK, New Zealand, etc.- Access to the OEM Manual
