If your truck is shifting strangely, sometimes hesitating before engaging gears or dropping power entirely during acceleration then you could be facing transmission solenoid problems. When transmission solenoids dont read pressure correctly, they can relay wrong information which causes the truck to shift haphazardly. The good news is that this problem is fairly easy to fix for the most part. As per the 2020 Ford F-150 Service and Repair Manual, clearing the transmission adpative shift tables usually resets the module. Worst case scenario you may need to replace the shift solenoids. You can get the full details from the service and maintenance manual in the link below.
Click here to get the 2020 Ford F-150 Service and Repair Manual
