This is a major problem in the F-150 where the display on the instrument cluster shows a different gear than the physical shifter position. This is caused by a loose or broken shift cable clip that does not properly secure the transmission linkage. The solution is to replace the cable clip with an upgraded one as per Ford Recall guideliness.
As with the other problems with this truck, I advise owner's to get a copy of the 2020 Ford F-150 Service and Repair Manual. It's an invaluable resource for Owner's and Technicians alike as it provides detailed procedures on how to maintain and service the truck.
Click here to Download: 2020 Ford F-150 Service and Repair Manual
