2020 Ford F-150 Transmission Problems and How to Fix them: 10 Speed 10R80
If your truck is jerking violently, having rough shifts between gears 3,4 and 5 and skipping some gears, you my friend are experiencing a malfunctioning 10R80 transmission. This is mainly caused by either a faulty TCM(Transmission Control Module) or worn out internal valve body components.
To fix this problem, I would encourage you to download and read the 2020 Ford F-150 Service and Repair Manual. It is an invaluable resource to owner's and technicians alike as it extensively explains how to maintain and repair the 10R80 transmission. It is developed by Ford so you're getting it straight from the horses mouth.
