If you own a 2020 F-150, then be very wary of mice. Strangely, Ford uses a soy based wire insulation coating that attracts rodents. They will chew on the wiring and suddenly you will be faced with multiple electrical faults.
The Solution is apply rodent repelant tape or pepper spray the wiring wraps. However before you spray, its best to read the Service and Repair Manual for a detailed guide to the wiring.
You can download the manual here: 2018-2020 Ford F-150 Service and Repair Manual
