The Harrier ASU60/ASU65 has a very sensitive Audio system and attempting to trace entertainment network faults or speaker dropouts without factory schematics can quickly turn ugly. It is easy to short circuit sensitive data lines if you start probing the pins blindly. It is also easy to destroy the premium audio amp, display modules or the integrated wiring looms so best to approach the repair with caution.
However, with the official audio system wiring diagram, the work becomes easy and straight forward. You get factory wire colors, connector pin locations and power routing details. Having this data allows you to then proceed cleanly to isolate parasitic battery draws, identify severed speaker lines, etc and trace component faults quickly.
This diagram will help you to answer this common questions:
- What is the radio wiring pinout for a Toyota Harrier ASU60/ASU65?
- How do I troubleshoot no sound from the speakers in a Toyota Harrier ASU60/ASU65?
- Where is the factory audio amplifier located on a Toyota Harrier ASU60/ASU65?
- Which wire is the main 12V ignition power feed for the Toyota Harrier ASU60/ASU65 audio system?
how to access the Audio System Wiring Diagram
Use the link below to access the diagram. The link will give you access to the entire database so I have attached the screenshot below to help you to navigate to the correct section. Also note that the year displayed is not the YOM but the document release date, so it will apply to the entire model. If you have any questions, just reply in the thread below and I will be happy to answer.- Access to the OEM Manual
