Toyota Harrier ASU60/ASU65 Brake Actuator Connector Pinout
This OEM pinout chart gives the terminal assignments, expected voltage thresholds and circuit functions for the A70 plug. It gives the procedures needed to trace broken wheel speed sensor inputs, verify heavy grounds and isolate hardware faults. Without this pinout there is a high risk of shorting live power feeds and destroying the brake actuator ECU.
  1. What is the pinout chart for the Toyota Harrier ASU60/ASU65 brake actuator A70 connector?
  2. How do I test ABS pump motor power and ground circuits on a Toyota Harrier ASU60/ASU65?
  3. Which terminal on the Toyota HarrierASU60/ASU65 A70 brake actuator assembly controls the communication link?
  4. What are the voltage specifications for the solenoid driver pins on a Toyota Harrier ASU60/ASU65 stability control module?
Click on the link below to access the complete OEM Manual, within it you will find the Brake Actuator Connector Pinout. I have given the screenshot below to help you quickly navigate to the section where the diagram is located. Once you find it, you can then print or save it. Let me know if you face any challenges or have any questions and I will be happy to answer in the thread below. Please note that the year in the document is not the YOM but the document release date so it covers the entire model range. Also note the document applies to all countries where the model is sold Including Singapore, Australia, Malaysia, Kenya, UK, New Zealand, etc.
Toyota Harrier ASU60 ASU65 Brake Actuator Connector Pinout
