This diagram provides circuit paths, ground shielding configurations and wire colours for the D69 connector. It has the correct procedures for back probing the sensor circuit, verifiy steady voltage delivery and resolve engine speed tracking faults. Without this factory diagram, there is risk of misdiagnosis which can cause damage to sensitive data bus and the ECM.
- What is the pinout chart for the Toyota Harrier ASU60/ASU65 crankshaft position sensor D69 connector?
- How do I test the 5V reference feed or ground circuit at the Crank Position Sensor on an ASU60/ASU65 ?
- What are the wire colours for the crankshaft sensor harness on a Toyota Harrier 8AR-FTS engine?
- How do you isolate an intermittent wiring fault from a failing crankshaft sensor when tracking down engine stalling in a Harrier ASU60/ASU65?
Click on the link below to access the complete OEM Manual, within it you will find the Crankshaft Position Sensor Wiring Diagram. I have given the screenshot below to help you quickly navigate to the section where the diagram is located. Once you find it, you can then print or save it. Let me know if you face any challenges or have any questions and I will be happy to answer in the thread below. Please note that the year in the document is not the YOM but the document release date so it covers the entire model range. Also note the document applies to all countries where the model is sold Including Singapore, Australia, Malaysia, Kenya, UK, New Zealand, etc.- Access to the OEM Manual
