This OEM driver power seat memory wiring diagram gives the complete circuit layouts, wire colours, and terminal pinouts for the memory seating system. It gives precise procedures for tracing faulty circuit paths, verifying sensor feed voltages and solving adjustment or memory retention failures.
- Where is the driver seat memory ECU located on a Toyota Harrier ASU60/ASU65?
- How do I test the position sensor circuits on a Toyota Harrier ASU60/ASU65 power seat?
- What is the pinout for the driver side seat memory switch on a Toyota Harrier ASU60/ASU65?
- Why is my Toyota Harrier ASU60/ASU65 driver seat not saving or recalling its memory positions?
Click on the link below to access the complete OEM Manual, within it you will find the Driver Power Seat Memory Wiring Diagram. I have given the screenshot below to help you quickly navigate to the section where the diagram is located. Once you find it, you can then print or save it. Let me know if you face any challenges or have any questions and I will be happy to answer in the thread below. Please note that the year in the document is not the YOM but the document release date so it covers the entire model range. Also note the document applies to all countries where the model is sold Including Singapore, Australia, Malaysia, Kenya, UK, New Zealand, etc.- Access to the OEM Manual
