Toyota Harrier ASU60 ASU65 Electric Parking Brake Wiring Diagram
Diagnosing and repairing the Harrier's computerized parking brake system without OEM layouts can be a nightmare. For those of us who have done it, you know how blindly probing the circuits can cause damage to the EPB module, wiring harness or introduce erratic lock/unlock behavior. The OEM layouts in this diagram give you immediate access to accurate wire colors, connector pin locations and circuit parameters directly from the factory. This makes your repair job fast, clean and error free. You can also easily test the switch assembly, verify high amp power feeds to the calipers and isolate faults within the safety system.
So get this OEM diagram and save yourself the stress and time. I have given the link below to access the complete OEM manual. Within it, you will find the EPB section. The screenshot below will also help you navigate to the exact EPB diagnostic and repair procedures.
