This OEM diagram for the front wiper and washer gives you the terminal positions, fuse ratings and wire colour codes for the non-sensing wiper system. It gives the factory map needed to verify voltage supply, test ground paths for the motor plug and safely resolve low-speed, high-speed or intermittent wiper failures. Without this factory schematic, you risk incorrect wire identification which can short the circuits within the integration panel.
- Which fuse controls the front wiper motor on a Toyota Harrier ASU60/ASU65 without rain sensors?
- How do I test the intermittent wiper switch circuit on a Toyota Harrier ASU60/ASU65?
- What is the pinout configuration for the standard front wiper motor connector on a Toyota Harrier ASU60/ASU65?
Click on the link below to access the complete OEM Manual, within it you will find the Front Wiper and Washer Wiring Diagram. I have given the screenshot below to help you quickly navigate to the section where the diagram is located. Once you find it, you can then print or save it. Let me know if you face any challenges or have any questions and I will be happy to answer in the thread below. Please note that the year in the document is not the YOM but the document release date so it covers the entire model range. Also note the document applies to all countries where the model is sold Including Singapore, Australia, Malaysia, Kenya, UK, New Zealand, etc.- Access to the OEM Manual
