This document gives you the precise electrical circuit pathways for the Harrier Ignition system, which will allow you to perform power and ground verification, circuit tracing and control signal analysis. It gives the reference layout needed to isolate faults affecting ignition coils and their connection to the ECM.
Without this diagram you risk damaging the ECM or the coil drivers and also replacing unnecessary parts let alone the wastage of time. So save yourself the headache and get this diagram if you are troubleshooting ignition problems. See the link below where to access it.
