Toyota Harrier ASU60/ASU65 LED Illumination Wiring Diagram
This factory LED illumination wiring diagram gives you access to the full circuit paths, wire colours and connector pinouts for the accent lights. It provides the necessary technical map to check for active power feeds, verifiy solid gounding lines and isolate lighting circuit dropouts without guesswork. Attempting to troubleshoot low voltage LED accent circuits without factory diagram risks incorrect wire identificatin which can easily overload delicate driver circuits or damage shared body ECUs.
  1. Where is the fuse for the accent LED illumination light on a Toyota Harrier ASU60/ASU65?
  2. How do I test the left or right LED illumination light connector on a Toyota Harrier ASU60/ASU65?
  3. What is the pinout configuration for the Toyota Harrier ASU60/ASU65 LED illumination light module?
Click on the link below to access the complete OEM Manual, within it you will find the LED Illumination Wiring Diagram. I have given the screenshot below to help you quickly navigate to the section where the diagram is located. Once you find it, you can then print or save it. Let me know if you face any challenges or have any questions and I will be happy to answer in the thread below. Please note that the year in the document is not the YOM but the document release date so it covers the entire model range. Also note the document applies to all countries where the model is sold Including Singapore, Australia, Malaysia, Kenya, UK, New Zealand, etc.
Toyota Harrier ASU60 ASU65 LED Illumination Wiring Diagram
