Toyota Harrier ASU60/ASU65 Low-Pressure Fuel Sensor Wiring Diagram
This OEM low pressure fuel sensor wiring diagram gives you the complete circuit tracks, wire colour codes and connector pinouts for the D62 plug assembly. It gives you the correct procedures to check sensor supply drops, test grounding tracks and isolate eletrical line faults from fuel pressure degradation. Without this factory layouts, you can easily damage sensors, high/low pressure pumps and the ECM.
  • What is the pinout chart for the low-pressure fuel sensor D62 connector on a Toyota Harrier ASU60/ASU65?
  • How do I test the 5V reference voltage at the fuel delivery pipe sensor on a Toyota Harrier ASU60/ASU65?
  • What are the wire colours for the low-side fuel pressure sensor on a Toyota Harrier 8AR-FTS engine?
  • How do you isolate an electrical harness fault from a failing fuel pressure sensor when diagnosing fuel system codes for Harrier ASU60/ASU65?
Click on the link below to access the complete OEM Manual, within it you will find the Low-Pressure Fuel Sensor Wiring Diagram. I have given the screenshot below to help you quickly navigate to the section where the diagram is located. Once you find it, you can then print or save it. Let me know if you face any challenges or have any questions and I will be happy to answer in the thread below. Please note that the year in the document is not the YOM but the document release date so it covers the entire model range. Also note the document applies to all countries where the model is sold Including Singapore, Australia, Malaysia, Kenya, UK, New Zealand, etc.
