This diagram gives terminal configurations and pin assignments for the H5, H6 and H7 connectors for the main body ECU. It gives precise circuit tracing, voltage and ground verification and pinout checks for the underlying body electrical systems managed by this module. Trying to test the main body ECU connectors without factory layouts is risky as incorrect wiring identification can cause accidental terminal damage and module failure.
- What is the pinout for the H5 connector on the Toyota Harrier ASU60/ASU65 Main Body ECU?
- How do I identify the wires on the ASU60/ASU65 Harrier Main Body ECU H6 and H7 connectors?
- Where can I find the body control module terminal wiring guide for a Toyota Harrier ASU60/ASU65?
Click on the link below to access the complete OEM Manual, within it you will find the Main Body ECU Connector Pinout. I have given the screenshot below to help you quickly navigate to the section where the diagram is located. Once you find it, you can then print or save it. Let me know if you face any challenges or have any questions and I will be happy to answer in the thread below. Please note that the year in the document is not the YOM but the document release date so it covers the entire model range. Also note the document applies to all countries where the model is sold Including Singapore, Australia, Malaysia, Kenya, UK, New Zealand, etc.- Access to the OEM Manual
