This OEM wiring diagram provides the full circuit paths, wire colours and connector pinouts for the v1 plug assembly. It gives the procedures required to verify solenoid power supply, check driver line continuity and fix engine lubrication control faults. Without this diagram, you can easily create a big problem through incorrect terminal probing which can damage the ECM or not even solve the lubrication control faults anyway.
Common Questions that this diagram answers
- What is the pinout mapping for the oil pressure switching valve v1 connector on a Toyota Harrier ASU60/ASU65?
- How do I test the control signal from the ECM to the oil pressure switching valve on an ASU60/ASU65?
- What are the factory wire colours for the oil control switching valve harness on a Toyota Harrier 8AR-FTS engine?
- How do you isolate an open wiring fault from a mechanically seized oil pressure switching valve solenoid for ASU60/ASU65?
Click on the link below to access the complete OEM Manual, within it you will find the Oil Pressure Switching Valve Wiring Diagram. I have given the screenshot below to help you quickly navigate to the section where the diagram is located. Once you find it, you can then print or save it. Let me know if you face any challenges or have any questions and I will be happy to answer in the thread below. Please note that the year in the document is not the YOM but the document release date so it covers the entire model range. Also note the document applies to all countries where the model is sold Including Singapore, Australia, Malaysia, Kenya, UK, New Zealand, etc.- Access to the OEM Manual
