this OEM wiring diagram is absolutely essential for network communication analysis, circuit tracing and power and ground verification across the automated tailgate network. It provides the exact pinouts required to trace signals for the power back door ECU, power lift motors, touch protection sensors, jam protection strips and rear latch assembly switches. Without this diagram, you risk severe misdiagnosis and incorrectly testing delicate sensor lines which can cause damage to the tailgate ECU, or a programming failure.
- Where is the power back door ECU located on a Toyota Harrier ASU60/ASU65?
- How do I test the jam protection sensor wiring on a Toyota Harrier ASU60/ASU65tailgate?
- What is the pinout configuration for the power lift motor connector on a Toyota Harrier ASU60/ASU65?
Click on the link below to access the complete OEM Manual, within it you will find the Power Back Door Wiring Diagram. I have given the screenshot below to help you quickly navigate to the section where the diagram is located. Once you find it, you can then print or save it. Let me know if you face any challenges or have any questions and I will be happy to answer in the thread below. Please note that the year in the document is not the YOM but the document release date so it covers the entire model range. Also note the document applies to all countries where the model is sold Including Singapore, Australia, Malaysia, Kenya, UK, New Zealand, etc.- Access to the OEM Manual
