Toyota Harrier ASU60 ASU65 Power Tilt and Telescopic Steering Wiring Diagram
This OEM factory column adjustment schematic provides you with accurate wire color codes, connector layouts and control unit pinouts. This diagram provides you with all the data that you need to reliably verify switch inputs, test motor operation voltages and resolve mechanical tilt and telescopic position lockouts. This will help you to: understand the electrical distribution for the column adjustment system, precise circuit tracing, power and ground verification and switch signal mapping.
Working on the electronic steering column circuits without accurate diagrams poses big risks. Probing delicate position sensors and high-current motor control wires without OEM diagrams can result in control module failure, short circuits and damage to the steering column assembly.
Below is the link to access the diagram. The screenshot below is also helpful as it will help you to nagivate to the exact diagram in the manual.
Toyota Harrier ASU60 ASU65 Power Tilt and Telescopic Steering Wiring Diagram.png
