Toyota Harrier ASU60/ASU65 Power Window Wiring Diagram
This schematic is essential for circuit tracing, power and ground verification and connector identification for the entire door power window system. It gives the precise pinouts and multiplex data connections linking the master control switch, individual door window switches and power window regulators - including auto up/down jam protection sensor circuits. Working on the advanced power window loop without the factory diagram risks incorrect wiring identification and accidental damage to sensitive door control units and main body ECU.
  1. Which fuse protects the master power window switch on a Toyota Harrier ASU60/ASU65?
  2. How do I test the power window regulator motor circuit on a Toyota Harrier ASU60/ASU65?
  3. What is the pinout configuration for the passenger side window switch on a Toyota Harrier ASU60/ASU65?
Click on the link below to access the complete OEM Manual, within it you will find the Power Window Wiring Diagram. I have given the screenshot below to help you quickly navigate to the section where the diagram is located. Once you find it, you can then print or save it. Let me know if you face any challenges or have any questions and I will be happy to answer in the thread below. Please note that the year in the document is not the YOM but the document release date so it covers the entire model range. Also note the document applies to all countries where the model is sold Including Singapore, Australia, Malaysia, Kenya, UK, New Zealand, etc.
Toyota Harrier ASU60 ASU65 Power Window Wiring Diagram
