This diagram is essential for circuit tracing, power and ground verification and connector identification across the rear glass cleaning circuit. It gives the exact electrical paths starting from the combination control switch, the back door flexible wiring harness to the rear wiper motor assembly and the rear washer pump. Working on this circuitry without this factory diagram risks incorrect wiring identification and damaging adjacent electronic components like the rear camera and power tailgate sensors.
- Which fuse controls the rear wiper motor on a Toyota Harrier ASU60/ASU65?
- How do I test the rear wiper motor connector on a Toyota Harrier ASU60/ASU65?
- What is the pinout configuration for the rear window washer pump on a Toyota Harrier ASU60/ASU65?
Click on the link below to access the complete OEM Manual, within it you will find the Rear Wiper and Washer Wiring Diagram. I have given the screenshot below to help you quickly navigate to the section where the diagram is located. Once you find it, you can then print or save it. Let me know if you face any challenges or have any questions and I will be happy to answer in the thread below. Please note that the year in the document is not the YOM but the document release date so it covers the entire model range. Also note the document applies to all countries where the model is sold Including Singapore, Australia, Malaysia, Kenya, UK, New Zealand, etc.- Access to the OEM Manual
