This OEM seat belt warning wiring diagram provides you with complete circuit layouts, wire colours and connector pinouts for you Harrier ASU60/ASU65 safety remind system. It gives you the exact technical guidance needed to trace broken buckle switch wires, test occupancy sensor signals and fix persistent warning chimes and dash displays. Without this diagram, you run the risk of incorrect testing and accidental damage to the SRS sub-networks and trigger other safety risks.
- Where is the driver side seat belt buckle switch connector located on a Toyota Harrier ASU60/ASU65?
- How do I test the front passenger seat occupancy sensor wiring on a Toyota Harrier ASU60/ASU65?
- Why is the seat belt warning light blinking when the belt is buckled in a Toyota Harrier?
- What is the pinout configuration for the seat belt reminder circuit on a Toyota Harrier?
Click on the link below to access the complete OEM Manual, within it you will find the Seat Belt Warning Wiring Diagram. I have given the screenshot below to help you quickly navigate to the section where the diagram is located. Once you find it, you can then print or save it. Let me know if you face any challenges or have any questions and I will be happy to answer in the thread below. Please note that the year in the document is not the YOM but the document release date so it covers the entire model range. Also note the document applies to all countries where the model is sold Including Singapore, Australia, Malaysia, Kenya, UK, New Zealand, etc.- Access to the OEM Manual
