If you are troubleshooting park release malfunctions, this OEM schematic delivers precise wire colors, circuit layouts and connector pinouts to help you systematically address these problems. Using this data, you can easily verify if the shift lock solenoid is receiving proper brake switch and ignition input, helping you to efficiently resolve physical gear selector lockouts.
Working on the shift lock actuator network without an OEM layout runs the risk of incorrectly testing and misdiagnosing the interface. Also, blindly pocking into these componenets can cause shorts, harness damage and unexpected rework. So better be safe than sorry. The link to the complete repair manual is below and also a screenshot to the exact location in the database where to find the Diagram.
- Access to the OEM Manual
