Toyota Harrier (ASU60 / ASU65) Starting System Wiring Diagram
If you are troubleshooting an engine no-crank fault on the Harrier ASU60/65, then the first place to look is the starter motor. This OEM starting system schematic grants you all visibility into the starter motor wiring, control switches and the integrated safety interlock circuits. With the pinouts and wire color codes containing in this diagram, you can execute drop tests, confirm command signals and systematically trace down the root cause of no-crank.
Below is the link to where you can access the Starting System Wiring Diagram as per the screenshot below.
