Ford F-150 IWE/4WD/2WD Problems and how to fix them - 2018, 2019, 2020
If you hear a loud grinding noise from your front wheels something I can best describe as 'metal on metal' or marbles in a blender, then the main culprit is the Integrated Wheel End(IWE). A loss of vacuum pressure causes the IWE 4WD hubs to partially engage. It's a very unsettling soud and you may think your truck is falling apart. The solution is usually to replace the faulty check valve, vacuum lines, or check if the hub actuator is damaged and replace it.
Proactive checks especially on the vacuum lines can arrest the problem before it happens. For more details please refer to the Ford F-150 OEM Service and Repair Manual. It's a wonderful resource for owner's, especially if you want to stay on top of problems before they happen.
Here is the link to the manual: 2018-2020 Ford F-150 Service and Repair Manual
