Toyota Harrier ASU60 ASU65 Power Steering ECU Connector Pinout
This pinout is used for essential terminal level testing, power and ground verification and signal line analysis on the electric power steering module. It gives pinout mapping for connectors o1 and o3, which enables you to verify high current battery feeds, heavy gauge chassis grounds, torque sensor inputs and multiplex communication bus lines. Probing electric power steering (EPS) controller plugs without factory terminal data poses a great risk of shorting motor circuits which can cause permanent EPS ECU damage.
  1. What is the pinout chart for the Toyota Harrier ASU60/ASU65 power steering ECU o1 connector?
  2. How do I test high-current power and ground distribution paths on a Toyota Harrier ASU60/ASU65 EPS system?
  3. Which terminal on the Toyota Harrier ASU60/ASU65 o3 steering controller plug handles the high-speed CAN bus data lines?
  4. How do you diagnose an intermittent steering assist loss by pinning out the steering ECU connectors for ASU60/ASU65?
Click on the link below to access the complete OEM Manual, within it you will find the Power Steering ECU Connector Pinout . I have given the screenshot below to help you quickly navigate to the section where the diagram is located. Once you find it, you can then print or save it. Let me know if you face any challenges or have any questions and I will be happy to answer in the thread below. Please note that the year in the document is not the YOM but the document release date so it covers the entire model range. Also note the document applies to all countries where the model is sold Including Singapore, Australia, Malaysia, Kenya, UK, New Zealand, etc.
